Error 9
Error 9
Can anyone help me with this Problem ?
While running the Analysis, I am getting this Error 9, and also while producing the Output Files, in EXCEL, or ACCESS  - can not be produced at all sad
RE: Error 9
What software are you using?
RE: Error 9
SAP2000, Version 10.....I was working quite well with it for some time, and now it occured. Tryed with reinstallation, but still same Error occurs....
RE: Error 9
While want to produce the SAP2000 analysis output files in Excel, here is what I am getting as warning blocking window, “Can not open Sap transfer file c:/docume?/user/locals?1/temp/tmp16.res !”
RE: Error 9
I've seen that before.  Try saving your file as a different name and then re-running it.  I think it gets confused with those dozens of temporary and other files it creates.
RE: Error 9
No, no result with this renaming sad
RE: Error 9
Try doing a Save As to another folder and run it from there.  I'm still suspicious of those temp files.
My only other idea is to backtrack and try to remember the last thing you did before the error starting happening.  Are you lucky enough to NOT have a geometry that would take very long to re-enter?  That's often faster and more reliable.
I've seen that error before, but can't remember how I got rid of it.
RE: Error 9
Thanks 4 help, so far I managed only to create ACCESS result files, not EXCEL, but that one is better than nothing, right winky smile
