Jumper to increase rating of 230kV disconnect
I've got a 230-kV disconnect rated at 1200A that I need to be able to handle a bit more (200-300A). I've heard of mechanical jumper devices that can do this. Could anyone give me some general information/manufacturers so I could do some research?
The switch is a double sidebreak Southern States Type RDC.
Thanks in advance.
Thanks in advance.
RE: Jumper to increase rating of 230kV disconnect
Please review properly if the offered revision or modification is very reliable.
Christopher Caserta
ccaserta@enorthhampton.com
Ph:904-225-0360
