How to use the principle of superposition of fields reasonably?
A simple concept of vector superposition or decomposition:
Let's take an example:
A pulsating vector could be decomposed into two rotating vectors like:
here
and
The following pictures show two cases of superposition:
Fig-01:
Fig-02:
Who could tell which picture shows the correct superposition or decomposition of the pulsating field?
RE: How to use the principle of superposition of fields reasonably?
What is your problem?
Gunnar Englund
www.gke.org
I would assume this might be a single phase motor.  The difference in the two diagrams is whether you orient the beginning of the vector at the center of the circle or at the airgap.
Are you trying to represent a 4-pole single phase motor?
