buck boost converter
i am trying to design a buck boost converter to output a controled 12 volts dc with a variable voltage input of 8-16V dc, i am having a hard time controling the voltage output, if anyone has a circuit like this or has any helpful suggestions please let me know.
RE: buck boost converter
If the output voltage must be very stable (better than 1%), you should combine a reference and a low offset OPA to feed back the (divided) output voltage signal to the error amp pin of the dcdc-ic. This second control loop shoud be at least 5 times slower than the initial circuit (often a current controlled PWM) to maintain stability.
If you have more detailed questions, let me know.
tiki
