Sheetmetal Edge Display
I have some formed parts that don't display the edges near the bend in the isometric view of the drawing.  Is there a config.pro option that controls the display of the edges?
Thanks in advance,
Farmboy
RE: Sheetmetal Edge Display
Use Black on white color setting the edge disappearance is due to the sheetmetal driving surface color of green which doesn't display well or at all when plotted.
I made a Mapkey to swap color plot the file and switch color back to Wildfire settings.
Michael
I can see the green fine.  I did try the black on white and the edges still didn't show up.  They also don't display when I print a monochrome(black on white) .pdf file.
I've fiddled with various display settings and I can't find the one the turns on the edge display.  I'm relatively new to Pro/E so I'm probably just not looking in the right spot.  Any advice would be greatly appreciated.
Farmboy
You can set it by the View Properties. They are called Tangent Edges.
I originally thought you were refering to actual edges which for sheetmetal parts plot poorly for the Green Edges.
On the Display Tab there is an option for tangent edges. Your drawing probably has this set to none. You can set the tangent edges to display as solid Hidden or Phantom Font.
Michael
jester
That worked! Thanks Michael.  The config.pro variable is tangent_edge_display.
Farmboy
