Offset load
Offset load
Offset load
How would I load a hole in a part that would receive a shaft that has an offset load?  (i.e. the shaft is 'L' shaped and has a load at the edge of the 'l'.
Thanks much!!
RE: Offset load
Draw a free body diagram. The sum of forces and moments equals zero.
RE: Offset load
meeker,
Can you model the shaft through the hole and apply the load to the end of it instead of the hole?  If I understand the problem correctly, you are applying a moment perpendicular to the hole.  Is that correct?
RE: Offset load
Thank you, I know how to do a free body diagram;  What I am asking is how do I simulate the force developed by a L shaped shaft in a hole.  I would like to do it without having assemble the shaft.  I know that it is done in the Force/Moment Load window, but I don't remember how, it has been many years)  The force is applied parallel to the hole but 6" in front of it (through the shaft).
