Background Mask on Text
I use a couple of different versions (2005 LT, 2006 full etc) and I cannot find a way to default the Text background mask to be on automatically.
It seems that I have to select the text that I want to have the backgound mask on and right click> background etc. If there are more required then I match properties. This is rather tedious if you have dims with diffent properties, and different orientation leaders etc.
Is there a way that the Background mask can be set to be on as standard?
Any comments would be greatly appreciated.
Thanks.
Thanks.
