How to boost pressure in cooling water line?
Hello
I need to hook up a new eqp to existing cooling water line. But the pressure in existing line is too small (assume 0.5 barg) I need at least 1 barg at device inlet. Is it possible to hook up a centrifugal pump to line? Then I could supply an equipment with water. Maybe I should use a diferent type of pump? Flow rate is ca 100 m3/hr.
Thanks for any suggestions.
RE: How to boost pressure in cooling water line?
check the following link for inline pumps which should just the thing for your application.
http
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
www.Engineering6ss.com
"The only constant in life is change." -Bruce Lee
