A572 to A992
A572 to A992
Can anyone tell me why the switch was made from A572 steel to A992 steel for typical structural steel? I know that A572 is still available, but A992 is what we spec and I believe the most prevalent.
does it have anything to do with ductility problems associated with the Northridge earthquake in California in 1994?
RE: A572 to A992
RE: A572 to A992
per AISC Technical Bulletin #3, dated March 1997"), giving an upper limit on the yield point. As far as I know, the main reason for this is structural design along the "strong column weak beam" philosophy--it's hard to ensure that your column outlasts your beam if you can't control the overstrength in your beam. My understanding was that the original intent was seismic applications.
Here's an article about it:
ht
I don't know what spurred the development of this spec. Maybe Northridge, maybe just growing awareness from designers that steel can be a lot stronger than that number (36, 50, whatever) that they punch into their calculators, maybe both. One of the sources I found said that the modified A 572 Gr. 50 grew out of the practice of making steel that could be dually certified to A 36 and A 572, which started in the early 90s.
http
Here's the old Tech Bulletin #3 (looks a lot like A 992):
ht
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
RE: A572 to A992
