Material Conversion Chart
First time poster.....does anyone know where someone can find any easy to use material conversion chart. I have what I believe is a German material spec and need to convert that into something I can understand, a US material!
Here is what I have.... Gusseisen EN 1563-GJS-X (GGG-SiMo 5-1) DBL4441.10.
It is a casting, but I have a feeling I may run into this more with other materials thats why I was looking for some sort of conversion chart.
Any help would be greatly appreciated.
RE: Material Conversion Chart
This question has been asked repeatedly.  Perform a search, looking for Stahlschlussel, and the ASM products Worldwide Guide to Equivalent Irons and Steels and Worldwide Guide to Equivalent Nonferrous Metals & Alloys.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
FYI, DBL 4441 is a standard from Mercedes Benz in Germany.  If it appears on a drawing that you are reviewing, then you need to ask your customer for the most recent revision so that you can properly quote.  This particular designation is a Si-Mo alloyed cast iron typically used for automotive exhaust manifolds.
