Flexible poylmers
Flexible poylmers
Hey folks,
I'm looking to produce flexible household mouldings. I've got the equipment to make moulds from various types of wood (by creating 16' 'negatives' from my regular mouldings). I would like to be able to pour the resin into the mould, have it set up slightly, and remove it in order to bend it to the final shape before it fully cures. Does anyone have any suggestions on how to go about this and what products to use?
Mike
Mike
RE: Flexible poylmers
Wood is not normally a suitable material for moulds unless you intend to thermo form.
What do you mean by flexible.
You say 16' Do you mean 16 inches.
To catch the cure in a state where it is not to sticky to handle and rubbery enough to both handle without pulling it out of shape entirely, but still form into shape will be a challenge.
How complicated is the shape.
How will you get it to release from a wood mould.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Here in The Colonies, it's getting hard to find actual wood mouldings anymore, even the ones finger- jointed from short sticks. The big box lumberyards stock plastic mouldings that I think are made of polystyrene foam, with a skin that looks like ABS. It's a bit more limber than wood. Most of it will bend to a 2 foot radius the easy way without heat. It's easy to nail, but it doesn't hold nails well. Anyway, that crap is flexible enough to follow any wall I've ever seen. So if he's talking about just conforming to a warped wall, I don't see a market for a b-staged product.
If he's thinking about just forming it around corners, e.g. to zero radius, Poisson's Ratio works against the idea. I.e., a molding of any thickness, folded over a sharp corner, is going to bulge in a rather ugly way.
Mike Halloran
Pembroke Pines, FL, USA
Now I see what he is getting at.
He wants to produce sheets of plastic to use in place of plywood panelling that he can bend into place for corners or to conform to irregularities in the wall.
That can possibly be done with sheet plastic. It will be expensive.
With some practice, sheet plastic can be formed into place with a hot air gun or strip heaters and a bending jig for tight straight bends. Acrylic, ABS or PVC can be used.
Another note, I've seen this process done before however it was brief. The resin was poured into a form and let set up, and then they proceeded to release the mould and lay it out on the floor where they slowly pulled it around a teplate that was cut to match the window. (Something like a 12"r).
This product would go over very well in my state but no one wants to wait the 4-6 weeks it takes to ship from a current supplier, so I usually charge them an arm and a leg to turn the arches from MDF, which is time consuming and, well, MDF is not a pleasure to work with.
Pics:
http://www.flextrim.com/images/flexprod.jpg
ht
http://flexibletrim.com/images/Products/photo2.jpg
Thanks again,
Mike
There are urethane and urethane foam systems with much greater flexibility. Suggest you google, or search on matweb for urethane and urethane foams, and talk to a supplier of these. Pat can probably give you a few ideas too. As pointed out by other posters, there is a limit to how far any material will bend without distorting the heck out of the trim shape.
The wood "forms" you are talking about will need a lot of reinforcement if you use them for a foam molding system, as these usually require a significant amount of internal mold pressure to work properly. Think many, many C-clamps and big backing boards.
A local company I interviewed with, Heat-Con Composites, makes a line of composite-curing electric "blanket" heaters and controllers. One use for these they are developing is to heat polyethylene-composite "boards" to allow them to be formed for curved decks/steps/stairs. This won't work with cured urethane foams, but might work with other thermoformed polymers/elastomers.
Mike Halloran
Another thing that may spark some ideas...
When I saw these manufactured, first, the worker took a 2-part mixture and simply poured it into a 16 foot mold that was open along the top. He waited as it chemically heated and cured. Then he realeased it from the mold, still hot, and layed it on the ground. There was very little smell eminating. While on the ground, he slowly bend it around the template and blocked it as certain points to retain the shape. The material, when fully cured, it quite flexible. It can be nailed, filled, painted or stained in order to look just like the wood it is replacing.
I wish I knew the chemical he was using. It seems to be a gaurded secret. I am still contacting numerous suppliers in order to find a solution.
Thank you all for your continuing contributions.
Sincerely,
Mike
