Screw Mate and Assy Qty. Question
I have a couple of questions.
1. I don't have the toolbox add-on so all my parts were imported from elsewhere or custom made. From my design library when I insert my flat head screws into a countersink the coincident mate always is upside down (the screw is sticking up rather than into the plate). After I insert them I have to then go back thru and reverse the coincident mate for each and every screw. How do I fix it so the flat head screws mate correctly with the countersink when I insert them in an assembly?
2. How do I change the qty of a part at the assembly level for a drawing BOM table so that I don't have to break the parametric link by simply over riding the qty value directly in the BOM table? An example: lets say I have a standard spring that is a common part (so I don't want to mess with the individual part file) and there are 1000 springs of type A and 500 of type B in a particular assembly. But I don't want to insert or show 1500 springs in the assembly, at the assembly file level how can I make 1 spring represent 1000 springs, and another spring represent 500 springs for the drawing BOM table?
RE: Screw Mate and Assy Qty. Question
2) Create configs of the springs. In each config create a "Unit of Measure" property and enter a value. (Config 1 = 1, Config 2 = 100, etc). The UoM property can then be read into a BOM column.
Eric
