Lossy Transmission Line Component Calculation
I need to determine the R, L, C, and G of a lossy transmission line at various frequencies below 1 MHz.  I have only one access point at an end.  Any suggestions would be appreciated.  My first attempt was to determine the input impedance and set it equal to sqrt{(R+jwL)/(G+jwC)} and solve simultaneously for real and imaginary parts.  It seemed messy and tended to blow up.
RE: Lossy Transmission Line Component Calculation
How long is the line ? At 1 MHz most likely the ohmic
parts are negligeable, unless the line is very long.
<nbucska@pcperipherals.com>
This is not an ordinary transmission line.  It is actually an insulated pipe in the earth of unknown length.  The particular line that I am testing is about 250 feet long before it makes a connection to the main line;  it then continues several miles.
What are you trying to do ? Using TDR to trace the pipe ?
detect leakage or break ?
Tracing pipe by injecting a signal and tracing the resulting magnetic field.  I am attempting to detemine the how different frequencies respond.
Public utilitis do this rutinelly -- why don't you find out
what they use.
You may also search for patent at wwww.USPTO.GOV
The telephone guys do this all the time.  Why don't you see if you can borrow a test set for DSL line trouble-shooting.  DSL frequencies can go up to several megahertz.  The better testsets will return all the values you are looking for.
Lewis
