Vector Network Analyzer
Does anyone know the difference between a Network Analyzer and a Vector Network Analyzer?
RE: Vector Network Analyzer
One of the main differences is a Vector analyzer will give impedance change versus time.  Say you have a mechanical component which has an inductance associated with it and the inductance is a function of mechanical position.  And then you want to know the impedance of the inductance as it is moving.  Or say you have a SAW filter and you want to know how its impedance changes with a frequency dynamic signal.
Hope this helps.
Lewis
a scalar network analyser will give the magnitude information but not the phase information
whereas a vector network analyser will give the phase info as well
for instance the sna will give the vswr of a circuit whereas the vna will give (on a smith chart ) the magnitude and angle of the circuit
