SCALING ASSEMBLIES - SW2007
Question...
Using Solidworks 2007, is there a command to SCALE up/down an entire assembly? I know you can scale (up/down) EACH individual part that is in the assembly. But is there a command to just rescale the WHOLE assembly as ONCE?
RE: SCALING ASSEMBLIES - SW2007
Each component of the assy can be re-scaled using the ModelRescaler macro at http
If you need scale down an assembly temporarily and don't care about the features, try saving the assembly as a part file (Save As, change filetype to part). Then use the scale feature in the part file to scale it up or down.
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
SolidWorks 2008 SP0.0 on WinXP SP2
