plastic used as a protective window on an LCD for outdoor use
I am looking for any suggestions on what type of Plastic I will need for an outdoor application on a moving vehicle. In short it will be used to protect an LCD Display. Therefore, it needs to be
1. As clear as possible (for viewing LCD Display in the day)
2. Resist scratching
3. Have UV and IR blocking
4. obviously resistant to sun damage
Thanks for any help.
RE: plastic used as a protective window on an LCD for outdoor use
Why does it have to block UV and IR.
If impact resistance is not really critical, and by UV blocking, you actually mean UV resistant, Acrylic would be your best choice.
If it requires very high impact resistance polycarbonate may be required, but with PC you sacrifice a few other properties. Some of these can be improved with surface treatments and stabilisers, but it's tendency to stress crack in the presence of some very common everyday chemicals is a real problem.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
It does require impact resistance so I think I will need a PC. You say PC is sensitive to some common materials. Will it be sensitive to the materials used in a car wash?
Thanks for your help
How about a transparent nylon? Pricey though - hope it's a small part - here you go - data sheet here:
http://w
Cheers
Harry
IR absorbers normally also take out a significant portion of the visable light.
Light absorbers may stop the LCD getting hot, but they will cause the cover to get hot, thereby heating the air between them and the LCD. It gives some reduction in heat at the LCD, but not nearly so much as window tinting sales brouchers would have you believe. There is no free lunch. The energy has to go somewhere.
PC is normally OK in normal detergents and alkalis only really effect it at higher temperatures (like starting at about 60 deg C and really ramping up at about 80 deg C)
The things that really get into it are solvents (from paints and adhesives) fuels and lubricants (from the aromatic hydrocarbons in there as additives or impurities) and chlorinated hydrocarbons. Also propellants in aerosols, perfumes, sun tan oil, dissinfectants etc can be a problem.
Pud is right, PC headlights have a protective coating. It tends to last 10 or so years, at least in the normal environment in Oz.
PC is occasionally used in tail lights when engineers or toolmakers stuff up and acrylic won't bend enough to allow assembly. These normaly are normally UV stabilised but not coated and do not normally solvent stress crack unless someone uses bug remover or solvent on them, but they do scratch so badly that at only 2 or 3 years old they look VERY second hand.
Additionally, LCDs don't like it very cold, so you'll probably need heaters when the temperature drops. You might need to have a simmer heater just to keep the moisture out of the box.
TTFN
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
Do you know if this can be used on plastic?
Demon3 is refering to fluorinated tin oxide-- just tin oxide won't do much. You certainly can get FTO to coat most materials (I've done it myself).
