About building vibration evaluation
Hi all,
I don't have much background in vibration analysis.
We're looking for a new building for our laser measurement system lab. We used a few Kistler 8393B2 (0-250hz response) to collect the vibration data for these new buildings and did some fft analysis. We want set up some criteria to evaluate the data and choose one of the building to move in. But what's start point I need to looking at? Is only the FFT I can work on the data? Should I start from these ISO or ANSI test and analysis stardard? I think I need to find out the sensitivity of our laser system first, but we don't know where to start either. Thanks for any quick put!
I'll post some fft plot for these test result.
RE: About building vibration evaluation
Here are links for 3 FFT plots:
http://fil
http://fil
http://fil
Does your equipment mfr have background vibration limits? They should.
Did I miss the units of the posted FFTs.
I think the X units on FFTs is Hz to Y Amplitude(unit mm?). It's just a data plot after the FFT.
As for the magazine paper, do you have more details, such as title...
Since this is a reasonably expensive decision I suggest you get someone who knows how to measure vibration to do the job.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Mike Halloran
Pembroke Pines, FL, USA
My questions is not only focusing on the choosing the better one, but also to find out and set up some criteria for the vibration evaluation for our future product and project. We're trying to learning. Thanks and please input any suggestions.
What laser measurements are you trying to make? Which ones are actually vibration sensitive?
TTFN
My new questions:
1. I used accelerometers to get the vibration data and I get the acceleration signals. How can get the velocity signals?
2. How can I get the root-mean-square (rms) values for the FFT analysis? What's the benefit of rms compared to the plain FFT data?
Thanks.
Again, you need to explain what LASER measurements you're going to do and how. Measuring linear vibration might be interesting, but it might also be TOTALLY irrelevant to your laser test setup.
TTFN
My question now:
I have the data for Acceleration-Time from the accelermometer. How can get the RMS acceleration/Frequency plot? It might be 1/3 octave frequecy. Any suggestions?
Thanks.
If I did one trial and collected 100000 data (acceleration-time), can I break these data into 100 set (100 data/set) and calculate rms for each set. I get 100 data and they're all rms data. Then I do the FFT for these 100 rms data. Can I say it's the RMS(acceleration)-Frequency? Other way, I just to do 100 trial test and do the rms for 100 trial. The only difference is sample space. Am I right or wrong?
Please tell me how can I to get the rms(acceleration)-frequency. Many thanks.
I took a glance at the book. It's a perfect fit for my requirements.
