Induction negative pressure calculation
Can someone direct me to a method of calculating the negative pressure experienced by an induction air hose that is connected between the air filter and intake manifold?
In most small aircraft, the hose used to connect the air filter housing to the engine air intake is SCAT, SCEET, CEET, or CAT. However, none of those is recommended for negative pressure applications. So, I'm looking for a hose that is rated for that application, but I can't find a reference to how much negative pressure is found inside that hose.
I will cross-post this to the aerospace forum as well.
RE: Induction negative pressure calculation
Unless you have a really poorly designed filter or a very dirty filter, the depression will be almost zero.
Downstream of the throttle is another matter altogether
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
