.DWF file conversion to an Autocad openable format
I have a .dwf that I really need to modify, but I can not import it in Autocad.
Browing this forum I found and tried the following solutions without results:
1- Open it using Voloview and saving it in the .dxf format. I obtained only a runtime error...
2- Open it in my browser trough Whip! and saving it. I obtained only a message like "DWG sorce not found".
3- I downloaded and istalled IcDWFin of IntelCAD, but my Autocad versions (Autocad 2000(i) LT and Autocad 2002) are not compatible with it.
4- Using VoloView I tried to convert it has .rml and import it later with Autocad 2002, I obtained a error message like "Markup object not found for model space".
Does exist any other solutions?
RE: .DWF file conversion to an Autocad openable format
Do you really forget of what program are you speaking about?
This might be a useful program: DWF to DWG Converter: ICDWFIN ver. 3.2.0.1 (released May. 21/2001). 14-day trial version can be downloaded at
http://www.intelcad.com/pages/dwfin/index.htm
I've never used this program, and I'm not sure whether it works or not.
http://usa.autodesk.com/adsk/section/0,,163301-123112,00.html and use WHIP for free from AutoDESK ,install it into your internet_browser, and you can save to dwg format. open an dwf file drawing, ckick with your left mouse on the drawing to select Whip User options.Then with your right mouse click, select SAVE AS to format *.dwg, or *.bmp, or dwf. Good luck with it,be happy.
Saving from Whip will not work w/ the new 2002 ver of Autocad. The new DWF ver isn't supported by Whip nor the old Voloview. The newer Voloview doesn't have a copy to clipboard nor the saveas function.
No perfumed, not coloured, just kind
