Automotive Driveline Geartrain Inertia
Guys, I'm having trouble calculating the inertia contained in an automotive driveline. This is a simple automotive 'live axle' design where torque is diverted from a single input (differential) to two axles.
Q1. Lets say that the inertia exiting the transmission output is 1 kg-m2, how does this change the inertial of the axle if the final drive ratio is 4.77:1?
Q2. Can I sum the inertia of the two axles together as an approximation? Can I sum the wheel inertia?
Thanks for looking, I've been having trouble figuring this out and I can't really find any resources.
-S
-S
RE: Automotive Driveline Geartrain Inertia
http
Thanks.
-S
