Dual Monitors
Dual Monitors
RE: Dual Monitors
You're thinking of trying a dual monitor set-up? Jeez, Rob, I figured you'd already be set up that way!
Aside from, maybe, display differences, I don't think running two different monitors like yours will cause problems. I've been using a dual monitor set up for a couple of years now and can't imagine life without it...
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
RE: Dual Monitors
You'd better loosen up your purse strings at SWW...I heard that you're buying the first two rounds for us "chumps".
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
RE: Dual Monitors
I have a Dell M90 laptop widescreen and a Dell 15" monitor. No issues running any programs, including SW, on dual monitors.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
RE: Dual Monitors
The only issue with two monitors with different resolutions is that you'll need figure out what looks best with the two of thme side by side.  It's a minor matter, however.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
