Balancing Axial Thrust
I would like if someone could clarify my doubts...
when a multistage pump has a balance axial thrust device (drum, sleeve or combination of both), is the axial thrust eliminated to the extend that it is not required axial thrust bearings?
If it should be required thrust bearings, what type of bearings? Hydrodinamic (kingsbury) or ball bearing? and the radial bearings?
I have a cross sectional drawing of a multistage pump with a hydraulic balance system and the only bearings that i can see are journal bearings, so It seems there is not any thrust bearings?¿?
thanks again in advance!
RE: Balancing Axial Thrust
Johnny Pellin
You might want to look a little more closely at that cross-sectional drawing.
stgrme
