UUID vb macro
UUID vb macro
UUID vb macro
Does anyone know, how can I show UUID with vb macro?
Thanks.
RE: UUID vb macro
with great difficulty. as far as I am aware the actuall UUID for the document is encryped / obscured. It is possible to extact the UUIDs for some of the features in the file (these have a UUID that is simmilar but not exactly the same as the documment UUID). To do this you need to process the document at a binary/hex level (not for the faint hearted) this is completly seperate from CATIA, CATIA's API and DS will have nothing todo with it. The official line on UUIDs is "The user need not know the UUID or change it". If it is any help SmarTeam does store the UUID of the file in its table. Also the PX1 license gives you API access to the send to functionality of CATIA.
RE: UUID vb macro
Can I ask you what you will do with the UUID ?
Eric N.
RE: UUID vb macro
Because somtimes we can excahange files and we are faced with drawing link problems. Then if I can get the uuid, I can check it.
RE: UUID vb macro
You can also use edit> links to check the referencing files. or also you can replace the link as well.
RE: UUID vb macro
Like Jimicatia said you can check the UUID with a drawing link... I do not know any other way to find out if you have the right file...
Eric N.
