large electric submersible motors
I am working on a large water pumping plant, and due to the field conditions submersible pumps are desirable. Each unit would be rated about 25,000 GPM @ a head of about 120 ft.I have tried KSB Germany, but have not been successful. I am looking this type of equipment.
mumo
RE: large electric submersible motors
ITT Flygt are a big player in this area.
www.flygt.com
25,000 GPM?
or GPH?
I don't think this is an electrical or control issue. You should re-post this in the Pump Engineering forum
forum407: Pump engineering
When you are done, please red-flag your original post so that you are not cross-posting.
The pump capacity is 25,000 GPM @ 120 ft. of head.
Thanks I will be seeking the Pump forum.
