NX3 PDF Plotting
NX3 PDF Plotting
NX3 PDF Plotting
I know this has been discussed over and over again.  But I am having troubles with it.
From the GTAC BBS, (Thread "NX3 Plotting to PDF") I followed the instructions, but I can't figure out how to rotate it.  It's always showing up 90 degrees.
I am using Adobe Elements/Distiller.  I set up a .bat file to copy the .cgm to a certain directory as a .ps.  I then just convert it to a PDF via right clicking on it.
I have the init files set up in the plotter configuration for each drawing size.
Justin Ackley
Designer
RE: NX3 PDF Plotting
I'd offer more advice Justin, but I always output from the main plot dialogue to a .ps file, then used Ghostscript/Ghostview to open the PS file and rotate it manually if needed.  Yeah, a pain, but for no more drawings than I was dealing with, not a big deal.
I think by plotting from the Plot Dialog, I could force the .ps file to be the correct orientation in many cases.  Been too long since I've used NX3.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
