shading select parts/sub assy in draft view
Here's one,
We are creating graphics (a lot of iso type views) for a manual. They want certain parts/sub assemblies in certain views shaded.
Is there a good way to do this. I just saw an intern doing a fill on every enclosed area of one of the assemblies which seems ridiculously laborious.
Is there a way to do it with shaded views but only shading certain parts? I had a play and couldn't work it out.
Ken
Ken
KENAT, probably the least qualified checker you'll ever meet...
RE: shading select parts/sub assy in draft view
Sorry!
Patrick
Thanks Pat, may be the way to go.
I was trying to do it based on similar logic to how you can change the line type etc for certain parts etc.
In your assembly set the part face style for the non-coloured parts to White Transparent, and the other parts to whatever colour you want.
Save the image as a jpeg.
Change the colours for the next image as reqired.
I've just created a powerpoint presentation from someones images that showed different stages of a build.
This was done by saving all the images from the same view set-up and just turning parts on/off and changing colours.
Setting the images to the same position and size on the powerpoint slides you can achieve a fade-in/out effect.
bc.
They are 2D, black & white/greyscale in the manual.
That said some of these may be available now in the model with MBD so it might be worth a look.
how about making the parts that you do not want shaded,
Making them "clear/Glass" in color,
You can define a more transparent color than what is
provided.
HTH
Frank
The tech illustrators like getting the images in dxf format as it allows them to edit it better. However sometimes they use photographs so somtimes a model image may work but sometimes it needs to be a draft view.
