How To: Add a variable to design table that can be used in equations.
My end goal is to add a variable in a design table that I can use in equations. The variable itself should not be in any sketch, as it's just a number (87%, 2.5, etc.). If I could find a way to insert global variables in the design table, then that would fix my problem, but it doesn't seem possible.
RE: How To: Add a variable to design table that can be used in equations.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Searching Eng-Tips forums
e.g. A line of .87" long could be used in an equation to calculate 87% of a value.
As Stefan pointed out, the rebuilding could end up being a PITA.
