Copper Slag containing 30% Si02 & 45% Fe
Is there anyway to get rid of silica in a refinement process like using a blast furnace to make pig iron?
I have read everything I can find on making pig iron but I haven't run across anything that contains 30% silica. Most of the pig iron specs I have found contain 3% silica.
I'm curious if anyone has any information on how I could get the silica reduced to a managable level to produce pig iron.
Does anyone have any expertise in this area?
Nate
RE: Copper Slag containing 30% Si02 & 45% Fe
Are you referring to silicon content or silica(SiO2). Pig irons contain nominally 3% Si.
In the copper slag that you have referred,SiO2 is 30% and it is very difficult to reduce SiO2 content and enrich your iron content.
SiO2 is a strong oxide and separating Si and O2 by reduction methods will be expensive and energy consuming.
I hope I have understood your needs and properly.
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
You are right about the silica. I mistyped when I was referring to 3% silica content in pig iron, I meant silicon content. My mistake on the ol keyboard. smile
Here is what I have from the lab. Can you provide any other help on this? I'm really just trying to see if I can even do anything with this pile of junk. Perhaps it can be recycled in the steel making process?
Ag          SILVER          < 0.10     OZ/TN LAB
Au          GOLD            < 0.004    OZ/TN LAB
Cu          COPPER          1.1        %     LAB
SiO2        SILICA          29.3%      %     LAB
Al203       ALUMINA         3.0        %     LAB
Fe          IRON            45.1       %     LAB
CaO         LIME            1.3        %     LAB
S           SULFUR          0.7        %     LAB
As          ARSENIC         0.019      %     LAB
Ba          BARIUM          0.064      %     LAB
Be          BERYLLIUM       < 0.001    %     LAB
Bi          BISMUTH         0.042      %     LAB
Cd          CADMIUM         0.004      %     LAB
Cl          CHLORIDE        0.007      %     LAB
Co          COBALT          0.017      %     LAB
Cr          CHROMIUM        0.045      %     LAB
F           FLOURIDE        0.109      %     LAB
Hg          MERCURY         < 0.1      %     LAB
K           POTASSIUM       0.746      %     LAB
MgO         MAGNESIA        1.354      %     LAB
Mn          MANGANESE       0.027      %     LAB
Mo          MOLYBDENUM      0.253      %     LAB
Na          SODIUM          0.231      %     LAB
Ni          NICKEL          0.005      %     LAB
P           PHOSPHORUS      0.029      %     LAB
Pb          LEAD            0.060      %     LAB
Sb          ANTIMONY        0.037      %     LAB
Se          SELENIUM        < 0.001    %     LAB
Sn          TIN             0.018      %     LAB
Te          TELLURIUM       < 0.001    %     LAB
Tl          THALLIUM        < 0.001    %     LAB
Zn          ZINC            0.340      %     LAB
What is the process that would be used to seperate the Si & O2 even if someone wants to try it? Would the silica flow off the iron in a blast furnace as slag and be at a managable level so that it would work for pig iron in the production of gray iron? Or steel making?
TIA!
Nate
As per the Ellingham diagram reduction of SiO2 is possible above 1500C. This might not be an economical way to reduce SiO2 .
Other than SiO2 your slag does not have any other element in significant amounts to be of commercial interest.
Edmund Burke
Can this stuff be crushed and then separated by flotation or frothing?
Yes, when you melt it the SiO2 will float, but it is hell on refractories and you have a lot.
The Cu is high also.
If this were higher value metals I might suggest acid digestion, but not for Fe.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
The material is small form 2" diameter & less. It could be crushed and separated I would think.
The strange thing is this material is a by product of copper refinement. And that is why I called is copper slag. That is what I was told it was. And the residual 1.1% copper is what they couldn't extract in the refinement process. But the biggest majority is iron. And that is why I was thinking it could be converted into pig iron.
I wonder if the material could be crushed and using a mag separator to pick up the iron and leave the silica, etc behind.
Any ideas?
Nate
Try posting in the extraction and production forum.
