pdf file converting, cleaning up lineweights & text
Good morning,
I am trying to convert a map to .pdf, I can get it to convert, but when you zoom in, in Adobe the text is unreadable and lineweights are blurry, I tried saving as a jpeg, then back to pdf, it loads faster but the lineweights and text are still blurry, I know it can be done, the old map was done and works great.
Autodesk Landdesktop 2007
Acrobat 5.0
Acrobat 5.0
RE: pdf file converting, cleaning up lineweights & text
David
Thanks for your help by the way!
Go to Acrobat help and look for AutoCAD in the index. There is a bunch of information there (but I don't see how to add the buttons to AutoCAD after the face).
David
This gives a clean pdf for screen & print, but I'm not sure about use for maps, never drawn them!!
