Eaten-up internals in X-changers
What can normally be done if the baffles, tie rods, and partition plates are very badly corroded, totally useless, but the tubes are still in good condition? We are having turnaround currently and it only last for a month. I need to think of the most economical, easiest, practical and efficient way of holding the U-tube bundles together.
RE: Eaten-up internals in X-changers
If the tubes are in fact salvageable, you could saw cut the bundle behind the tubesheet, shortening them the tubes by an inch or two more than the tubesheet thickness, then replace the baffles with an alloy of a similar composition to that used for the tubes. Of course if the tubesheet is to be reused you would also need to extract the tube stubs prior to hanging the tubesheet.
This procedure would result in a small loss of surface area but potentially a large material savings.
-Christine
Great idea except that there are tube cutters specially made for cutting tubes off right behind the tubesheet. It would result in a cleaner cut and less surface loss due to saw considerations and less clean up to the tubes. There are also tools for extracting the tube stubs. Any heat exchanger service/repair company should be able to do that part of the work.
rmw
Mike
If a bundle is to be replaced, a budget foreast has to be made way before the Turnaround. The problem is, the budget was not to fit replacing the bundle. I am just talking about modification that can last for couple of years until the next Turnaround, and until then we will surely be able to replace the bundle. It's all about dollars and cents.
Well, we do what we have to do.
Mike
fluid,pressure,time ....weld,weld-o-lets on the vessel walls at 180 degree locations. Thread thru small nylon or teflon rods between the tubes. Tye off and plug with bull plugs.
