evaluation of damaged X-45 turbine vanes (industrial Gas turbine)
What is the best way to investigate the residual life of X-45 turbine vane? The parts may have been subjected to several repairs. I need to evaluate the general status to decide wheter or not they can be repaired again and employed again.
RE: evaluation of damaged X-45 turbine vanes (industrial Gas turbine)
Contact Liburdi Engineering in Ontario, Canada. I had worked on several root cause investigations and for specific metallurgical analysis of failed blades and to determine remaining life, I had used them. They are probably the best in the gas turbine and jet engine business.
http://www2.liburdi.com/liburdiengineering/index.php
