Weld assembly fem
Weld assembly fem
Hi all!
I would like you to tell me how to weld FEMs which belong to an assembly fem...
I've read a thousand times the manual but I cant make it work....
fem connector points, lines... I'm really dizzy...
Thanks in advance
Cerati
Thanks in advance
Cerati
RE: Weld assembly fem
I have an assembly fem already.
I went to "define connectors" on meshing to create a line connector which is suppossed to be used for welding.
But I can make it work. There is some "lengths" you have to specify, and everytime I "generate"the weld, it fails.
Help!
