CAD for Flexible Circuit Board using SolidWorks
hi,
I was wondering if it is possible to convert 2-D drawing of a flexible PCB design using OrCAD into a 3-D drawing version in SolidWorks?
If it is possible, what file conversion program should I use?
Basically, the 3-D CAD drawing should show the thickness of the flexible PCB, the flow of the copper conductor lines and the electrodes.
RE: CAD for Flexible Circuit Board using SolidWorks
CircuitWorks is this best for this, but unfortuneatly, to see tracks you need an IDF 4 output which Orcad does not support (only IDF 2).
Pete
I can't seem to convert max file to idf file using OrCAD.
How do I convert?
What software should I use?
Does OrCAD PCB Design editor convert max file to idf?
thanks
In Orcad Layout use File>Export>Layout to IDF. I do not use PCB Design editor, but I think IDF export must be available.
Pete
