Update dimension lines
Hi all
I am using NX5. I have already dimension lines drawing in drafting, but when I change something in modeling,these dimension lines become hidden lines.Have any tool update them automatic? Could you give me some advices? Thank you very much
Velto
Velto
RE: Update dimension lines
If I have understood your problem correctly, once you enter drafting application you are unable to see the dimensions, but when u update drawing the dimensions become visible, For this u can do one of the following,
1. Ctrl+Shift+K then press Esc
or
2. In modeling application, Ctrl+B and then Ctrl+Shift+B
-Regards
man2007
Many modeling operations result in edges being deleted or replaced, and any dimensions referencing those edges will lose their associativity. Efficient modeling methods will minimize this.
In the drafting application. Edit>Drafting Object Associativity.
Hope it helps
Hudson
If they are blanked then you should follow "Man2007"'s post.
From your question >>> "but when I change something in modeling"
What is the "something" you change, that would help a lot in answering the question.
Velto
Edges come and go, but faces tend to hang around.
Ed
