Seat inserts material
Hi there,
I want to know where I can find more information regarding PEEK, PTFE, RPTFE.
Rgds   Marcell
RE: Seat inserts material
utlandmah,
      that's a quite general question... which can be generally answered with: "try to search the web"...!
      Could you please be more specific, so that we probably may better help you?    winky smile
Thanks,   'NGL
You are right. These are the seat inserts in ball valves and I want to see the difference between them.
Rgds   Marcell
Obtain Teflon information from Dupont Performance Elastomers.  Obtain PEEK information at victrex.com.
I think one difference is temperature rating. The others are probably chemical applicability.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
