External pressure chart for unassigned material
Hi
Have anyone experienced designing an ASME vessel with unassigned material against external pressure? I am wandering which external pressure chart shall be used for unassigned material, especially LDX 2101. Please suggest.
RE: External pressure chart for unassigned material
jt
LDX 2101 is standardised by ASTM/ASME. It is accepted as equivalent / exceeding the S32101. Refer to Outkumpu's website.
gr2vessels
I don't have at hand the code case 2418, that might help you, provided your Client agrees to it. Also, check out the post in the search box above, for this material and the code case 2418.
cheers,
gr2vessels
gr2vessels
Thanks for all useful responses. That's really help.
Prasit
