Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just a quick note to say, "THANKS!" for these forums...The site is very well layed out and easy to use. Thanks for bringing us together - we need each other."
Geography
cascadco (Automotive)
26 Oct 07 18:56
Does anyone know, how can I replace drawing links correctly?
Thanks.
snowfire (Mechanical)
26 Oct 07 22:03
UUID must be the same.
Forever Young
DBezaire (Automotive)
30 Oct 07 10:59
cascadco
Take a look at this post.
http://www.eng-tips.com/viewthread.cfm?qid=200503&page=1
Derek
vellu (Mechanical)
30 Oct 07 16:36
You question is quite short and I don't know wheter this explanation is obvious to you, but this is the normal procedure:
Open the 3D model.
Open the drawing and drawing as active document:
Edit / Links
Replace / With loaded document
Sometimes (if error occures) you have to first remove the links and then try again.
1 Nov 07 14:24
vellu,
in case of the uuid is not same, can your procedure run?
PeterGuy (Automotive)
1 Nov 07 16:12
the redraw it proceedure
huntwe (Automotive)
29 Feb 08 8:35
what is the uuid? where can it be found & can it be changed so the change links works in drawings? I am wasting a lot of time recreating similar drawings from scratch
itsmyjob (Mechanical)
29 Feb 08 9:17
sorry but you cannot change or access the UUID.
With a script you can actually change the link of the view but you will have to relink dimension...
To avoid further problem :
When a drawing is made from 3D file A, if you have to change the geometry, use the same 3D file A in order to create 3D file B, then your drawing can be link to 3D file B.
Eric N.
huntwe (Automotive)
29 Feb 08 10:16
i still get error message "drawing refuses the link" when 3d file A is used to make 3d file B. Is there a setting that is preventing a re-link? I am a converted solidworks user now using catia, solidworks relinks drawings with ease and saves a ton of time detailing. Catia is made by the same company, don't understand why this is so difficult.
29 Feb 08 11:39
Can you explain how you create file B from file A ?
Eric N.
weavedreamer (Automotive)
29 Feb 08 11:57
Perhaps one day, a disgruntled software user will program a better approach. Untill then, consider packaging your part inside a product and pointing the drawing back to the product. New part - Open Product, change Part, open Drawing, Smile. Then just add extra files to manage into your scenario.
huntwe (Automotive)
29 Feb 08 12:12
create file A, then: file, save as, new file name (file B). I didn't modify file B in any way from file A except change the file name. I created dwg A then saved as dwg B in the same way as the part file. Then I go to dwg B and try to change link from part A to Part B. Thats when I get the error message, am I doing something wrong? In solidworks you had an option to redirect the link as you opened the dwg. I don't see this option in catia, does it exist somewhere?
ferdo (Mechanical)
29 Feb 08 13:31
See also http://www.eng-tips.com/faqs.cfm?fid=1318
Fernando
huntwe (Automotive)
29 Feb 08 14:03
Thank You Ferdo, it works! The key is that you must use (save management) to save the files AND....you must save the part & dwg file the same way.
liquidlunch (Industrial)
29 Feb 08 14:17
If you created file b with the "save as new document" selected you gave file b a new uuid.  I also think if you created file b before you made the drawing of file a it won't link up to file b.  Try creating the drawing of file a before you create file b because when you do a save as on file a to file b it will prompt you to tell you of the impacts it has on the links and ask if you want the links to be applied to the new part.
I always use save management when trying to maintain links.  Since you haven't changed file b in any way it should be the same as file a, correct? Since the drawing was created from file a you should be able to use save management to save both as new file b.  I always start with a fresh session of v5, open both the part and drawing and then you can right click on the drawing and select all pointed.  You will see that the part will highlight with the drawing showing they are linked.  Using the pattern name type *-rev1 (just an example) then select apply pattern.  Both the drawing and part will have -rev1 added to the end of the part name. You will be able to see the path it will save to in the next column. Now do a save as on both of the files to a directory (example //part#-rev1).  Make sure the new path shows up in the location column and action states "save" on both of your files then select ok. If the save as is greyed out you have to click in the epmty area below the parts to deselect the files. I always exit out of catia and open a new session and the new files as a sanity check.
Hope this helps
29 Feb 08 14:19
I guess I am not a fast enough typer.  Glad it worked out for you.
CatMann (Aerospace)
3 Mar 08 5:40
Infact, I also have redrawn the entire drawing again and agian many times, but with no changes. Im irritated much with DS.
This especially does not work out if the drafting goes at a differnt end than the design end. When a designer updates his design again and again with the modifications and sends the file(which is a with a new name(that name with rev added), certainly with a different uuid. But the drawing at the other end does not accept this new file.
Moral of the story is: Like parent child relationship. its always catious of working on only one design file that has been used previously for creating this drawing. So, keep shuffling the same design model file between drafter and designer.
Do you understand? or Have I confused you further?
CatMann
4 Mar 08 2:01
New name doesn't mean new UUID.
You can have 1000 files with the same UUID.
Forever Young
JuhaEdag (Automotive)
12 Mar 08 10:52
Very annoying but UUID will dictate your work unfortunately.
I also thought it was stupid because you could use the same drawing format even views and sections in v4 and save a lot of time.
But even more annoying is that sometimes you get the "drawing refused the link" without any reason. In fact I shouted and called one of our designers an idiot because I thought he had broken the link by doing a "new from" but I was wrong he managed to relink it from a new location to the released and locked file. I felt really bad about it because I thought it was impossible to cheat the system.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
