Hole Table Tag
Hole Table Tag
Hole Table Tag
Does anyone know how to change the tag on a hole table?  I have a tag that says "J1" and I want to change it to "B1".  Any ideas???
Mechanical Engineer
Varian Medical Systems
Salt Lake City, UT
         l     l
        0]lllll[0
     l__l      l__l
RE: Hole Table Tag
There is no slick way of changing the tags. The tag in the table can be manually changed via the Equation option, but that does not change the hole tag.
A new column can be added to the table and the cells manually populated with text; and tags (text) can be added manually to the drawing view, and  but they will not be associative.
cheers
RE: Hole Table Tag
When creating the table, holes can be selected in the sequence you want them to be listed.
cheers
