Cooling Tower Set Up
Hi Guys, I am managing a building with 4 cabinet type induced draft cooling towers with a capacity of 100 tons each. The elevation/air space from the bottom of the cooling tower to the foundation is 4 ft and the distance from the tower to the wall is also 4 ft. Attach is a schematic drawing on how it was installed. Technically, turbulent air passes through from one direction only. My question is, can anybody check if the cooling tower 1 and 2 are starved with fresh air? If so, how can we induce fresh air with this limited space/set-up? We cannot bore holes to the wall since theother side of the wall are all confined spaces. Or will CT 1 & CT 2 work efficiently with this kind of set-up? Sorry if I had to use PPT as Autocadd is too expensive to buy. Thank you in advance for your advises.
Mechathan
RE: Cooling Tower Set Up
Mechathan
