CON-CALC - FREE Concrete Mix Calculator
http://www.billmcmillan.com/CON-CALC ;  FREE
CONCRETE MIXTURE PROPORTION CALCULATOR
  ALL ON ONE PAGE
Easy to create, print and save.
CON-CALC will be useful to anyone experimenting with different concrete mixes. It will allow easy documentation of the test samples, and the various characterisics associated with each test batch in either METRIC or US measures.
CON-CALC can provide a history of test results detailing various mix formulas. There is a push-button facility for printing and for  saving the current file in the CON-CALC directory, in the project name subdirectory with a date/time stamp and the project description.
CON-CALC will automatically create the CON-CALC directoory on the "C" drive, and will automatically create and maintain the various subdirectories and the files in them.
CON-CALC is based on Excel and Visual Basic for Applications, and requires Excel to run. It does not have to be installed or loaded as an "addin". Just open it in Excel, click the "DOC" tab, and begin entering data.
RE: CON-CALC - FREE Concrete Mix Calculator
I tried the website noted and got the message "Website Not Found".  Could you reconfirm the link?
Thanks in advance.
The URL has a trailing blank which shouldn't be there.
Remove the blank and it should work.
Hi, bill, thanks. I downloaded it but seemed to behave badly in my Exccel Office 97 Spain's release..., also seemed congealed (a demo or so) after the first time I openend the sheet, may be a device of bad functioning in my said Excel. A pity since seems to have very nice features.
Thank you anyway.
