ProE PDF Creation
ProE PDF Creation
In WF, you can create a PDF file from picking a simple icon. When the file is created, it is stored on the user's C drive. I would like for it to be stored in the working directory or work space. Is this managed somehow in the config.pro file?
Also, we have 100's of ProE drawings that need to have a PDF file created. Is there a batch utility available that can create multiple PDF file without having to open every drawing and manually creating the file?
Thanks for your help.
RE: ProE PDF Creation
For batch plotting try: Spekan Batch
http://www.ptcuser.org/rugs/U53/tips/utilities.htm
Cheers,
JW
I use http://www.pdf995.com/
Heckler![[americanflag] americanflag](https://www.tipmaster.com/images/americanflag.gif)
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
o
_`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
http://www.profilesmagazine.com/p25/tools.html
Fighter Pilot
Manufacturing Engineer
For what it's worth, I also regurally create pdf versions of all the drawings I do.
I have 'mapkeys' set up for all the sizes A0, A1..A4 and also for single and multiple sheets.
I find this works fine. Not quite batch printing though.
Speedy
