Using Block Lanzcos or Subspace for result is better
I am meetting impediment in select Subspace method and Block Lanczos methodIn task simmers number riêng. Block Lanczos, first mode equal zero. Subspace mehtod, first mode don’t equal zero. Result of two different methods is different. Neither know I am have to who blunder where Neither, waitted you helps. And with respect to a large structures, Block Lanzcos method or Subspace methods  for results is better. Thanks !
RE: Using Block Lanzcos or Subspace for result is better
I would suggest you:
a) Read the documentation on both methods.
b) Fix your apparent problem with rigid body motion.
As for method, I always use the block lanczos unless the model is prohibitively large.
Can you tell me why you use Block Lanzcos?Or suppose you like its
I agree with Stringmaker. In addition, Block Lanczos is to my experience the fastest undamped eigenvalue solver in Ansys.
Alex
Thanks a lot!
