Pile Cap Depth
Pile Cap Depth
Pile Cap Depth
Does pile caps have to be below frost depth?
So if I have grade beams, then its minimum thickness
would be 4feet?  Lets say I designed a grade beam to be
500mm thick,  do I have to make it 1.2m?
RE: Pile Cap Depth
Frost depth would control the level of the bottom of your grade beam, but not the depth.
RE: Pile Cap Depth
Adding to hokie66, you can always construct a concrete stem wall above a grade beam, and the wood framing over that.
Mike McCann
McCann Engineering
RE: Pile Cap Depth
IMHO: I would check with your contractor (if known). Depending on the situation, and location of the project, many would prefer to cast the grade beam/pile caps the full thickness (in your case 1.2m) rather than cast a 500mm thick grade beam and come back and build a 700mm tall stem wall on top. It takes a lot of extra concrete but save forming labor.
RE: Pile Cap Depth
A heated building with external vertical perimeter insulation does not have to have pile cap base below frost depth.
