Need to Source FDA grade LLDPE Cling Film Resin
I need to source an FDA grade cling film/strech wrap resin.
- or - alternatively locate a PE formulation to use.
My understanding is that LLDPE will likely be my best choice.
Additionally I have been advised that PolyisoButelene would be an additive that would 'bloom' to the surface and contribute to the 'cling' effect that I am looking for.
I would MAJORLY appreciate any direction that anyone could point me in for this project.
I have been contacting all the majors and distributors but no one seems to have a solution.
My application requires 40 mil sheet so I will also be looking into my manufacturing process choices: cast sheet, extrusion, blown down, etc.
Thanks in advance for any feedback you may have,
Randy
RE: Need to Source FDA grade LLDPE Cling Film Resin
LLDPE is the normal choice.
I may be wrong, but I thought some EVA was included to increase the tack and elastic or stretchy nature.
Both LLDPE and EVA are available in food grade.
1mm is a very thick film and could more accurately be described as sheet. Film is typically 1/10th that thickness or less.
Cling wrap mis normally blown film, but 1mm thick "film might be best as so called cast which is actually extruded onto a calendaring roller and squeezed down to correct thickness as it cools on the roller surface.
I have no first hand knowledge of PolyisoButelene.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thank you Demon3 -
The Borealis Group web site does show a FG5199 formulation that is specifically done for strech wrap/cling film.  They call out anti-oxidant, anit-fog and cling additives included.  That's great!  I'll contact them and ask about sampling and min order and such.
Now my next great challenge will be finding a way to process this LLDPE resin to get a 40 mil sheet...  I think a cast sheet line may be my best bet...
Thx again for the insight!
Randy
patprimmer - thx for the heads-up on the EVA component, I'll ask about that for sure.
Yea, I would agree that the cast sheet method seems best.
The thickest I've heard of for a blown upward 'film' line is 20 mils.
Thx!
Randy
Another additive to give stickiness is Styroflex, a type of SBS. It's compatible with PE. At 5-10% it allows downgauging, improves recovery after stretching and improves tear strength.
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
