Overriding dim will not let drawing be saved as DXF
When overriding a dimension with "a" for example, I cannot save the drawing as DXF or DWG. This is every designer here. We are all running XP 64, SW2007x64 SP4.0.
When I click the box to not override it, I can then save it as a dxf or dwg.
Very strange. Anyone heard of this or have advice?
I sent it to our VAR and I think they are sending it to solidworks.
I have attached a screen shot of the issue and circled where I am talking about.
RE: Overriding dim will not let drawing be saved as DXF
Under dimension text, if you change "<DIM>" to "a", will it work?
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
^ Yes. Then it worked. But, when I use the override value box, it will not work. (will not save as DWG or DXF).
Thanks for the reply, sorry took me a day to reply, I have been in meetings all day.
I knida think that is a good thing.  When you override a dimension, the value no longer matches the geometry.  I would not want to accidentally send this type of fudged part to a cnc manufacturer.
-Shaggy
^ Well we are not overriding it because we want to make it a different number.
Example.
You have 3 versions of a pencil.
12345-1 = 4 inches long
12345-2 = 5 inches long
12345-3 = 6 inches long
On the drawing you have the pencil dimensioned but you have the length equal to "A".
In your design table that you have on the drawing you have a column for "A". The "A" is above the 4,5,6.
12345-1 = 4
12345-2 = 5
12345-3 = 6
You want to override the length dimension to say "A"
I tried it here and it works.
Chris
AutoCAD 06
ctopher's blog
^ It's weird. Its just all of our computers.
Our VAR sent it to solidworks today and told me that chances are it will not be figured out.
If we just erase <DIM> and type "A" it will save as dxf/dwg
The "override dimension" feature is relatively new.  I have always done what you are describing by erasing <dim> as well.
-Shaggy
I heard from solidworks. Its a known bug. Its fixed in SP5. SP5 is due to be released next think (my VAR thinks).
WOOT!
