SW Part Popups from Assy
Greetings Civilization,
   I've just noticed that on some assemblies, after I close the viewing window, there are still additional parts open that I never opened. These parts belong to the assembly that I just closed. I'm assuming these parts automatically opened when I open the assembly. Does anyone know of options that control such behavior in the opening of assemblies?
Tom
Failure is a prerequisite of successful design
RE: SW Part Popups from Assy
If a part in the assy is mirrored or derived in some way from the "pop-up" parts, those parts will be opened.
cheers
Go to Tools > Options > System Options > External References and set Load referenced documents to None
cheers
Ok. Thanks CBL
