Revising parts and breaking links to drawings
Tried to search for this one without success - it's bound to have happened to someone out there (or we are just plain stupid)!!
It happened as follows:-
1. using revision manager, an assembly was opened and the 'where used' found what models and draft drawings were used in it.
2.Some parts were selected with their relevant drafts and up-reved so we could make some changes.
3. Changes were performed to the parts and everything looked sweet.
4. The draft drawings were then to be opened and updated, but when we looked for them they hadn't been up-reved.
What happened was that the search command was not expanded out enough to catch all the draft drawings (in a seperate folder).
We now have 7 parts with no reference to any draft drawing.
Is there any way to restore a link from the new part model to the last revision of the draft drawings and updating them?
Thanks in advance
Andrew.
Thanks in advance
Andrew.
RE: Revising parts and breaking links to drawings
Copy the previous rev drawings before re-linking and set the copies to the new rev.
Then use revision manager to link the new rev drawing to the new rev model.
I assume you know how to change the links with revision manager using 'set action to replace'?
This happens here more often than I'd like to admit.
KENAT, probably the least qualified checker you'll ever meet...
also possible:
- open the draft(s) in question
- MainToolBar --> Edit
--> Links
--> select the link that is no longer valid
--> Change Source
browse to it and select it --> open
Chnage Source
dy
