default settings
default settings
default settings
Is there any way (short of creating a template) to change the default from metric to English without reinstalling Solidworks?
RE: default settings
You can change it for any document, but the default setting comes from the default template.  No need to create a new template, just modify the existing one.  Not a big deal.
Timelord
If you're in an active document, got to Tools->Options->Document Properties->Units to change the dimensions.
Your best bet is to create templates the reflect your needed dimension style(s). You'll need to create separate templates for parts, assemblies and drawings.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
