Power combiner vs mixer
Hi all,
could anyone explain the difference between a power combiner and a mixer?
Thanks in advance!
Thanks in advance!
RE: Power combiner vs mixer
A mixer is a frequency translator. In a down converter mode of operation, you supply an LO (local oscillator) and an RF (Radio Frequency). The difference frequency comes out of the IF (intermediate frequency) port. Have a look at the RFcafe for these elementary definitions.
http://www.rfcafe.com/
thanks for you answer. I´m doing IMR measurements. We used a frequency mixer from minicircuits to get the third intermodulation product. However, I have noticed that some people use a power combiner. So that´s when I started to consider the difference.
I checked it in RF-cafe but I couldn´t find any definitions, could you please tell me where is this section? I tried under Appetizers then definitions.
I don´t understand you definition in the case we are using them, IMRR measurements, two-tones for example 88 and 89MHz same frequency. Could we use both the power combiner and the frequency mixer for this measurement?
http://www.rfcafe.com/references/electrical.htm
Try this:
http
You really ought to consider getting yourself some more text books.
http://www.rfcafe.com/references/books.htm
(Analog or RF)
I tend to buy several per year by way of Continuous Professional Development.
