Threaded Holes in a Hole Table
Is it possible to add threaded holes to a hole table.
I've tried it - it doesn't seem possible. Straight holes are working fine for me. The help notes say that hole tables only apply to straight holes.
I have a drawing with up to 70 holes on a flat plate, about 3/4 of these holes are threaded. Using a hole table would be ideal.
Any suggestions?
It will save me a lot of work and hassle if I can figure this out !!!
![[banghead] banghead](https://www.tipmaster.com/images/banghead.gif)
Any suggestions?
RE: Threaded Holes in a Hole Table
this might give you some options....
ht
h
Thanks for your help, but as I understand it your suggestions refer to ISO.hol which specify the input tables for the holes, not the 'Hole Table' which is essentially a report in a drawing.
I found the following
http://www.sigmaxim.com/html/smartholechart.html
Looks like this is what I need.
Anybody ever used this?
Speedy
sweet find
can't tell you much abou that but hsve heard good things about smart electrode
http://www.sigmaxim.com/html/smartelectrode.html
